NEWINGTON
Continuous-blowdown block valve reduces startup time, plus. . .
Breaker retrofit protects transformer
Triple-redundant sodium analyzers protect equipment, personnel
more |
KLAMATH FALLS
Replacing a closed-code FT8 control system
more |
ENCOGEN
Transitioning a legacy base-load plant to cycling duty
more |
EFFINGHAM
Reducing LP drum pressure increases cold-weather output
Equipment supports core-skills training, proficiency
Arc flash data sheets, labels create a user-friendly program
Better organization of paperwork in the control room pays dividends
more |
NV ENERGY FLEET
Workforce design using Hoshin planning
more |
JOHNSON COUNTY
Optimizing chiller operation
Membrane installation/removal tool reduces physical stress
more |
SEVIER
Collaboration, focus on constructability result in efficient design meeting challenging schedule
Adapting vent stack design to handle flashing of process-steam drains
Voltage-class evaluation results improve cost-effective performance
more |
LEA
Ammonia-tank level monitoring contributes to high plant availability
Hydrogen system modification improves safety, balance sheet
Wastewater reclamation project produces big cost savings
more |
HOLDEN
Control system mods enable 10-min starts; increase reliability, flexibility
more |
DOGWOOD
Inline repair saves 9-chrome HP stop/check valve
Management training for day-shift O&M technicians
Extreme-weather preparedness increases availability
more |
McCLAIN
Improvements to plant permit process benefits safety
more |
ROKEBY
Comprehensive hazardous spill mitigation strategy
more |
GRANITE RIDGE
Chemical delivery drivers welcome safety cards
Wireless monitoring of HRSG drain valves pinpoints energy waste
Communications initiative leads to multi-faceted returns
Engineered solution to facilitate generator inspections
more |
SALTILLO
ACC fan-blade pitch optimization
Gas-turbine-inlet air filtration improvement
Fuel-oil recirculation arrangement saves money, mitigates spill risk
more |
SABINE COGEN
Safety database developed in-house effectively tracks, validates contractors
Monitoring CEMS gas bottle pressure ensures compliance
more |
MEAG WANSLEY
Post-maintenance checklist for critical instruments
‘Scratch out’ accidents program promotes safety vigilance
more |
FARIBAULT
Freeze protection, Minnesota style
HRSG chemical feed system improvement
more |
ATHENS
Detecting pump issues before they cause outages
more |
KIAMICHI
Severe-storm, tornado readiness key to personnel safety
NERC CIP-006: physical security perimeter challenges
more |
CROCKETT
Student internship program helps combat aging workforce
more |
HARQUAHALA
Safe practices for inspecting, maintaining cooling towers
more |
HIGGINS
New, safer method of rigging halves time for ACC gearbox change-out
more |
BRIDGEPORT
Preparing plant, workforce for hurricane conditions
more |
BUNDY
Natural-gas blowdown system assures a safer working environment
more |
LINDSAY HILL
Cooling-tower automated basin temperature/two-speed fan control
Removable platforms in cooling-tower fan shrouds improve safety
more |
OSPREY
Start faster, earn more
Seasonal readiness refresher training
more |
TERMOEMCALI
Well water, bypasses, new procedures eliminate debris issues on plant starts
Fuel-tank retrofit helps preserve biofuel
more |
TRACY
ACC gearbox oil removal piping
GT hazardous-gas monitor access mod
more |
ARROW CANYON
Multi-facility horizontal management planning
more |
LENZIE
Steam-line drain valve inspection program
more |
WASHINGTON COUNTY
Using condition-based vibration monitoring for critical equipment
more |
WALTON COUNTY
Reducing hydraulic-oil system varnish
more |
AL SANDERSVILLE
Commitment to conservation reduces annual electric bill by $100K
more |
KLEEN ENERGY
Contractor management program advances culture of safety
more |
CENTRAL ALABAMA
New valving protects against damage to tubing, piping
more |
JUNIPER ENERGY
New process conducive to more accurate financial reports
more |
