Company: JASC
URL: www.jasc-controls.com
Company Description:
JASC provides process control improvements for any industry. We evaluate system or sub-system performance and develop patentable designs to maximize productivity. Our ability to manufacture hardware, as required, provides comprehensive solutions for the most challenging operational problems
Products & Services:
Check Valves, Purge Air Valves, Servos, Water Injection Valves, Flow Monitors
On-Demand Video
Customer References/Workscope
GRU: JASC worked with GRU to complete a system overhaul and upgrade to water-cooled liquid fuel check valves on their 7EA GE engines to provide reliable transfers from oil to gas.
Tampa Electric: JASC provided water-cooled liquid fuel system upgrades.
ATK: JASC provides high-speed, motor-driven pintle valves with electronic control for metering of high-pressure gaseous hydrogen and silane for ATK-GASL (Ronkonkoma, NY).
Calpine: JASC provides liquid fuel valves for Calpine.
Honeywell: JASC developed both single and dual-channel high-speed, motor operated pintle valves for metering of liquid and gaseous fuels and high-speed servo valves for active combustion control for Honeywell Engine Division (Phoenix, AZ).
Hamilton-Sundstrand Power Systems: JASC produces servo valves, servo actuators, pressure regulators, flow dividers, solenoid operated relief valves and fuel controls for Hamilton-Sundstrand Power Systems (San Diego, CA and Windsor Locks, CT).
NASA: JASC provides high-speed, motor-driven pintle valves with electronic control for NASA’s Hyper-X Hypersonic Experimental Research Vehicle Fuel System.
JASC provides fuel control components for Parker Aerospace Nichols Airborne Division (Devens, MA) and Parker Aerospace Fluid Systems Division (Irvine, CA).
Pratt & Whitney: JASC provides servo-actuated, hot gas pintle valves with closed-loop electronic control for Pratt & Whitney Rocketdyne (West Palm Beach, FL).
Rolls Royce: JASC provided an actuator and electronic control for the Rolls-Royce/ Liberty Works (Indianapolis, IN) YJ102R engine that will power the RATTLRS supersonic demonstrator vehicle.
Japan’s Seal Tech: JASC works closely with Seal Tech (Tokyo, Japan) to provide Niigata Power Systems with hydromechanical and electric controls for power generating gas turbine engines.
Tactair: JASC manufactures close fitting spools and sleeves for various applications and precision flow grinding for Tactair Fluid Systems (Liverpool, NY).
Whittaker Controls: JASC provides a proportional solenoid operated pneumatic servo with mechanical force feedback for aircraft bleed-air control for Whittaker Controls (N. Hollywood, CA).
Industrial Valve Refurbishment
Point of Contact
Schuyler McElrath
Business Development
864-350-4332
smcelr8176@aol.com
Marla Evangelista
Sales and Marketing Director
602-300-3703
marla@jasc-controls.com
