Addressing stress corrosion cracking in the turbomachinery industry – Combined Cycle Journal
Sulzer.com
Stress corrosion cracking is a common problem affecting turbomachinery components such as rotor discs, steam turbine blades and compressor impellers, and is a major factor driving component repair. This type of cracking may lead to catastrophic failures which result in unplanned down time and expensive repairs.
A comprehensive root cause failure analysis is always needed to determine and confirm the root causes. Based on the findings of the analysis, different methods can be used to alleviate the cause of stress corrosion cracking. The design of the component, operating environment and other factors should be considered when selecting a method to mitigate stress corrosion cracking.
Read more
Sulzer is a leading independent repair specialist that can provide turnkey solutions for turbomachinery such as steam turbines and compressors; from inspections to preventative maintenance and complete overhauls, including redesigning components for improved efficiency and reliability.
With a global support network of 180 world-class production facilities and service centers across the globe, Sulzer can provide an immediate response anywhere in the world and call upon decades of experience in delivering successful repair projects. Our technology-based solutions maximize reliability and lifecycle cost-effectiveness.
Our offer Our company Applications
Social channels
LinkedInLinkedInTwitterTwitterFacebookFacebookYouTubeYouTube
InstagramInstagram
