Simple solution removes varnish, increases turbine efficiency – Combined Cycle Journal
Tackle varnish and improve turbine efficiency with Shell EcoSafe Revive
Shell EcoSafe Revive is a solvency enhancer fluid that can be incorporated into most turbine oils to reduce the issues associated with varnish formation and fluid instability.
Adding the recommended amount of Shell EcoSafe Revive requires no conversion process and reduces reliance on expensive varnish removal, abatement and remediation techniques. It is miscible and compatible with most commercial hydrocarbon-based turbine fluids, filter media and elastomers, as commonly applied in rotating equipment.
Learn more about our services at shell.us/power
