Visit Siemens’ Customer Extranet Portal for details on its comprehensive 501F update – Combined Cycle Journal
The Siemens session at the 2020 501F Users Group began with a high-level update on the Siemens Energy spinoff. Also highlighted was Siemens Energy’s roadmap to “Making Energy Greener.” A comprehensive gas-turbine update followed with technical updates on these topics:
    • Register now: 501F Users Group Virtual Conference. Starts Feb 15
      Hexavalent chromium residue.
    • Air-separator radial rubs and axial wear.
    • Exhaust manifold.
    • Advanced two-piece exhaust.
    • D5 turbine through-bolt fracture.
    • Bearing-bore drop-measurement tool.
    • New high-performance Row 4 turbine blade.
    • Peak firing and experience with ULN (ultra-low NOx).
    • Parts availability.
    • Torque-tube cracks.
    • Recent SGT6-5000F5 event.
    • Thermal-performance upgrade summary.
Next came a presentation on Brownfield Engine Exchange (BEX) which outlined the benefits and the process for a BEX and provided examples of several projects implemented by Siemens Energy. Following this was a generator update—including a fleet overview, discussion of generator findings observed during outages, and a review of various technologies to help reduce maintenance.
The session closed with a discussion of plant assessments (inclusive of operational assessment, performance/thermodynamic evaluation, availability, reliability, maintenance evaluation, and upgrade capability) and solutions to drive operational flexibility—including emissions reductions, adjusted maintenance intervals and faster cooldowns, enhanced-performance starts and stops, and alignment to grid requirements through load gradients. Operational enhancements for Siemens and Westinghouse steam turbines discussed were fast synchronization, fast speed and load ramps, fast close of bypass valves, fast shutdown, variable load-rate capabilities, variable speed rate potential capability, and considerations for speed roll times.
Most of the material presented is available on Siemens Energy’s Customer Extranet Portal. If you are an owner and/or operator of the company’s power generation equipment and do not have access to the portal, use this link to request it.
